southeastflorida
Im in the planning stages of a solar system and thinking of going with 24 volts system. what’s your opinion re Two 12 volt in series vs. one 24 volt (Lifepo4 of course). I like the idea of two batteries incase one goes out, I can still get a 12 volt battery easier (especially if its covered under warranty and I’m waiting for a replacement)? Do the BMS work together when two 12 volt are in series. Will one shut off early leaving one not fully charged? It would seem cheaper and easier in some respects to use two 12 volt in series, but this may be a flawed idea. I also like the idea of having separate charge controllers and inverters (modular to replace components should one break) maybe another flawed idea. Im a fan of Victron solar charge controllers and inverters. Several (or many) Victron charge controllers can work together to charge the battery bank-I like the redundancy if one goes bad-it would just reduce the amps of charge to the bank?).
