After months of pontificating, I have finally pulled together the electrical design for my RV conversion.
Let me know what you think. This is my first version and I would much rather fix as many problems at the pixels on a screen stage as I can.
Victron's SCCs load output, where present as terminals on the device, has the same rating as the controller in general. 20A in this case (100/20 model). The SCC has no real tolerance of over current. 20A means 20A. This could be likened to the behaviour of a fast fuse. I have seen capacitors in cheap ebay buck regulators trip a 10 amp model's load output. A thermistor took care of it but there's other ways too which I'm sure Haldor is aware of. I should test a 100/20 and see if it's as sensitive as the 10 amp models.I see you are running all DC loads through the MPPT load port, have you investigated the maximum current this port can handle? And if the port can still pass through current from the battery bank when the MPPT is not active.
Battery power is available without any solar input at all.
It has certainly grown. I am an EE and absolutely intend to do everything in a professional, safe and code compliant manner.Getting too deep for me. I only have 400W solar. No shore. No alternator. I do recommend connecting the green shore earth-ground to the chassis closer to the plug instead or in addition to the far side of the Victron. Just a safety thing to avoid "hot skin" condition on the van
That is a momentary contact push to start circuit. The toggle switch upstream is how you turn it off. The capacitor looking things are normally open relay contacts.Haldor, hi there, I'm following this in the background and I'm at a similar stage to you as in design. We're going slightly separate ways with power distribution but essentially on the same page. I've noticed your inclusion of a 12v relay (R12V) and a push to make run switch. Then you have a switch (12V on) which i assume is an enable system switch. What is the function of the device you've marked as (R12V) that looks like a capacitor symbol...??? Where is your 'holding in' contact and what is the stop/disconnect method or am i thinking to conventionally from a system automation point of view...??? I'm not trying to be a smartarse here because i think you've done a cracking job of the diagram and as an electrician myself i do like to scrutinise a drawing, can't help it as I'm sure you do the same...!!!
100% got you, under voltage shunt drops the load and R12V coil de-energises opening R12V N/O contacts, easy peasy automation..!!That is a momentary contact push to start circuit. The toggle switch upstream is how you turn it off. The capacitor looking things are normally open relay contacts.
The idea is the 12V loads are not critical and if the low voltage cutoff engages, I don't want these to turn themselves back on automatically when the battery voltage recovers.
I am using Visio. I find it to be very easy to use.100% got you, under voltage shunt drops the load and R12V coil de-energises opening R12V N/O contacts, easy peasy automation..!!
Where or rather what app you using for the drawings..?? I'm a dinosaur with CAD so hopefully it's idiot friendly...!!
This is my understanding as wellTo avoid further polluting the Electrodacus thread https://diysolarforum.com/threads/e...and-inverter-charger.13860/page-5#post-161692
Here is my understanding of correct electrical grounding symbols.
Yup. I have two grounds in my system. The van chassis ground and the negative house system busbar. I have them as separate symbols so I can explicitly show what is connected to each as well as where the two ground systems are connected together.This is my understanding as well
(with the acknowledgement that in practice the second symbol "earth ground" is often used a generic symbol for 'ground' as well as the symbol for earth-ground)
If you refer back to the original image posted, it got earth and chassis confused I think. As for 'signal ground' and 'power ground' I'm unfamiliar with these terms. From context (your schematic) I take signal ground to mean 'negative return' or 'grounded conductor'?
