3boysatbeach
its expensive but, my system design requires batteries to be on other side of garage from the inverter and transfer switch which is a total of 30 ft total cable length run thru soffit to a distribution block for the battery rack. I understand ideally batteries should be closer to the inverter.
I have not bought an inverter yet but given all the research i have done so far:
1) if i use a EG4 18k, all the lugs seem to max out at 2/0 so do i unitap 4/0 to 2/0 at the lugs? is this the way to do this?
2) if i use a Solark 15k, it seems i can run 4/0 all the way to inverter
Appreciate any help on this in advance.
thanks.
thanks.
