Hi - I bought an Epoch battery (manual attached) and it won’t charge via solar, in particular using a 480W 60.5 Vmp (7amp) solar panel and a 100/20 Victron 12/24/48v MPPT.
I read today in the manual the “Charge voltage range” is 56.8V and float voltage “54.4~55.2V” but the recommended charging amperage was 50amps.
I tested my solar panel today with a multimeter today around lunch and it was maxed out at 7.15-7.2 amps.
Does the MPPT compensate for lower amps to help a battery charge anyway ?
Any other ideas what could be the problem ?
