Rick403
Installing Solar system on my 42’ Rv Big Country Heartland.
4900 watt of solar
24 volt system. (?)
This is what I have so far.
Inverter
EG4 6000XP Off-Grid Inverter | 8000W PV Input | 6000W Output | 480V VOC Input | 48V 120/240V Split Phase | All-In-One Solar Inverter
Batteries
Quantity of 4. Total 1600ah
Litime 12V 400Ah LiFePO4 Lithium Battery 3200W Max.
Solar Panels
Quantity of 10. 490 watt panels.
Removing 2 roof top Ac and replacing with 22.5 seer dual zone mini split mounting compressor in the rear frame.
Needing help to determine if I should wire this in 24 volt are 48 volt system. mini split is a 24 volt Ac.
Need help determine what to use to step down to 12 volt to run my other rv stuff including auto leveling jacks.
4900 watt of solar
24 volt system. (?)
Inverter
Batteries
Solar Panels
