MADE MY SYSTEM BIGGER (6000XP X 50A RV)
Jason flores
Las vegas nv
I seen several post with people saying they couldnt run the rv heater at night so i thought what if i bought a 1000 watt ceramic heater and run it at night ..i originally had one 6000xp eg4 w/ 9,000 watts on my solar array 18x500w(max capable) with 48v 610ah lifepo4 batteries . I decided after looking threw comments that this would NOT be enough for what I wanted to do .
Full 37 ft 50a rv a/c -heater -water heater -tvs etc
I also have a seperate refrigerator. I get 5-1/2 hours of direct sun (no shaded areas) temps during the day are 40°-50° f at night down to 6° f
I would need to run my heater at night as well as 2 fridges (rv and residential). Tvs ? and a small 500w heater to warm the insulated shipping container that batteries and inverter is in . I want to strictly run off solar during the day not draining batteries . In summer I'll need to run the a/c at day time and power tools while building this pre fab cabin ..
So I decided to beef up the system with 18,000 watt array , Two 6000xp parallel , and 905ah of lifepo4 batterys . I'm hoping I won't have any issues .
Who are these people? You talking about the propane furnace? It's insane not to. Most efficient way to make heat unless you have a mini-split or rooftop heat pump.
Horrible idea. Resistance heat is a massive energy hog. An RV furnace outputs about 30,000 BTU/h or about 9000W.
The ONLY practical use of electric heat in an RV is an electric blanket with a huge comforter on top of it to seal you in snug like a bug in a rug. It can be 40°F in the RV, and the blanket on low can almost make you sweat!
Depends.
Absorption/propane type or compressor like a residential fridge?
I think this answers it. If the RV fridge is propane, you need to run it on propane. A 7.6cu-ft unit will use about 5kWh/day. A 12cu-ft unit double door will use 9-11kWh/day. The residential fridge (20 cu-ft or so) likely doesn't use more than about 1.5kWh/day.
Glad to see you said "insulated." I didn't insulate mine, and the only good the 1500W heater does it to push 30A through the battery to warm it up from the inside. :)
Well, that should improve things. You'll want to introduce your high energy use items one at a time.
I'm honestly thinking if shtf propane will not be accessible so I want to be 100% solar . We only get 6 inches of snow a year and an average of 310 sunny days a year .
I hear you. I'm headed that direction too. It's just MUCH more demanding.
Ditch the resistance heating and get a mini-split with heat pump function for heat and replace that absorption fridge. Either get the 12V cooling unit or swap it out entirely. We swapped our 12cu-ft norcold after the cooling unit failed with a 10.1 cu-ft energy star refrigerator... cut consumption down to 0.8kWh/day and the added depth of the fridge makes it feel much more roomy/usable than the 12cu-ft unit.
