New England Rhinoceros
- Oct 24, 2022
- 55
A bit long winded but I am confused and frustrated.
I bought a whole house system from Shop Solar Kits a little over a year ago. I have eighteen 365 watt panels wired into two LV6548 inverters which charge two 9.2kw Big Batteries. We currently live in an RV on our property and the array was purchased so when we build a house next year we will have the power needed to operate our home. It seems like overkill for an RV and in my mind we should have power for days. We are frugal with our usage, we don't leave lights on when not in use, etc. All our appliances are gas, fridge, range, water heater, heat. We have a tiny wood stove that we use to heat and the heting system really only comes on overnight when the fire burns down or during the day when we aren't home. Everything is wired into an electrical panel and we have a 50amp double pole breaker that plugs into an RV cord to power the RV.
A year ago I was having trouble getting my generator to connect to my system when the days were dark enough to not get the solar I needed and spent a LOT of time on the phone with the "help desk" people at Shop Solar. What I didn't know then and learned through this forum was that I needed an inverter duty rated generator. Once we got one of those our system connects and charges no propblem. Prior to learning that the "help desk" had me changing numerous settings in my inverters and not once was mention made about an inverter duty rated generator.
Last night we had approximately 85% charge in both batteries. After 2 hours of television, with a single lamp on in the living room, one of my batteries had drained down to 15% and the other battery was discharging to bring that battery back out of the red. The television is a 40" flatscreen that was energy star rated, have had it about a month. Why would two hours of TV and a single lamp devour about 8kw of power? Are some of my settings in my inverters incorrect? Many of the settings don't line up with the default settings that I was told to try and change because of the charge problems I was having and I'm so confused and frustrated.
I will be hit or miss in response on the thread today but any and all options anyone might have would be greatly appreciated. Thank you all in advance.
Rhino
Rhino
