Thanks for this thread. I'm trying to understand whether the 6000XP will accomplish my desired goal and would appreciate some input.
My starting battery is a temp solution comprised of LG 18650s in a 14s3p setup (Lithium ion, ~10Ah) just to have something in place. The permanent solution will be the same cells in a powerwall of ~ 200Ah. Given the battery chemistry, I only want to use my batteries as a backup in the event of grid outage.
- PV array is 4k. Plan is to setup a critical loads panel that would draw <3K, with the intent to draw from solar during the day and then have the inverter switch over to grid to run the circuits if solar is insufficient. In the event the grid was down and solar was insufficient to power the load, the system would then pull from the batteries.
Is this a viable option w/ the 6000XP?
