AZ Solar Junkie
Maricopa, AZ
I know a lot of systems - for example the 18kPV, Sol-Ark 15k, etc. - have in their specs a higher inverter output rating when also getting power from solar vs. from batteries only. The 6000XP does not, so I presumed 6000 watts / 3000 watts on either leg was the limit before it would switch to bypass mode. I happened to run our electric clothes dryer in the middle of the day today and discovered that indeed, the single 6000XP is handling it along with all the other loads I have on the system without switching to grid bypass. Ran at roughly 110% of the capacity on both legs for the duration of the dryer cycle - about 6,600 watts total without ever switching to bypass and no issues at all with the loads. In all fairness the demand was cycling up to that level for several minutes and then back down again for a few minutes as the heating element kicked on and off during the cycle, so it wasn't like a full hour of 6,600 watts continually, but still I'm happy. I'll have to test it again during the solar day with even more loads and see if I can find the limit - maybe 8,000 watts? Who knows? . In any case, this means I have the option even with my single 6000XP of using the dryer during the day as a dump load, which is good because my batteries have been getting full by 1pm or so and leaving too much of the available afternoon solar on the table.
@EG4_Jared - seems like this capability probably should have been quantified and made it into the specs in the manual, or no?
