The Growatts can be paralleled in multiples including 3 phase.It is phase sensitive in the sense that each leg is 180 degrees out of phase with the other.
That is the tricky part about using two inverters to create 240 volts. It is important to know how to make them work properly. Do they create true split phase when sycronised? Or do you just get two 120 volt inputs and no 240? I don't know because my inverter is 240 volt split phase.
