Hello everyone! I'm new here and struggling a bit trying to set up my first inverter (a Growatt 6000T) in my 5th wheel (a 2021 Jayco Pinnacle MDQS). I have attached a crude wiring diagram to hopefully explain my current situation. First, I built a battery and installed it in the front storage where the generator would typically go on my trailer. The trailer is "generator prepped" and gives me great 6/3 AC access to my transfer switch from the front storage. Next, I put a Growatt 6000T in the battery compartment which is also in the front storage. I wired the Growatt to the battery and "generator" wiring. Viola! Everything works great! The inverter can power the whole coach off the battery... The next step is getting the "AC input" wired up. This is where I'm running into my first problem.
I ran the 3 wires the Growatt wants (Hot1, Hot2 and Ground) from the inverter up to the transfer switch. I disconnected the shore power from the transfer switch (Hot1, Hot2, Ground and Neutral) and connected the Hot1, Hot2 and Ground to the Growatt. I didn't know what to do with the neutral so I capped it and turned on the power. Immediately, the surge protector (connected between the receptacle and coach plug) got really angry and turned red saying that it wouldn't supply power as the RV has no neutral connected. The coach runs fine on the Growatt using the battery, but I need to use the pass through function as well as charge up the battery when needed. The solar is still not connected. I tried bonding the neutral to ground but the surge protector did not like that either. I had considered removing the surge protector from the equation, but wanted to get a little clarity before proceeding with any potentially dangerous experiments. What is the correct way to connect this neutral wire?
I have a couple other questions about my system setup, but want to tackle the issues one at a time. Namely, I'm concerned about the 12v converter that came with the coach and the whole 48v/12v "interface". The 30A breaker to the DC/DC converter is currently tripped to allow the factory converter to charge the 12v system on its own. Once the Growatt powers the 48v bus from its AC input (Charging), I will remove the factory converter and allow the DC/DC converter to power the 12v system. Also, are there any concerns with the two 12v SLA house batteries in the system? I kept them in to reduce the surge when drawing high amp DC loads (levelling jacks/slideouts), but had originally planned to remove them. They fit, so I was hoping to keep them as long as there aren't any issues.
Thanks so much in advance! I'm extremely satisfied with the progress so far and the "proof of concept" watching the inverter crank away producing 4,500 watts continuous from the battery I built. Now just to figure out this neutral wire!
~M.
Also, here's a picture of the battery I built... Just because I'm so proud of it!
~M.
