Edit Update: Not so unlike others a half day later after repeated failures to update it appears to be fixed. I can only assume something is busted and either SS, EG4 or Lux has something set up so they can see specific failures happening and are possibly stealth fixing the issues. I have seen stranger things done to avoid showing there is an issue. Things generally don't magic themselves better. I would like to know the truth about what is occurring, why it is occurring or how its being fixed.
I was already leery enough of having a way to remote access something in my house that could be turned into a destructive device by altering settings in such a way that could cause a fire, short or otherwise especially when said item comes from a communist china. I understand ease of access for the installer, but there is no firewalls here, Its risky business.
*******OP ***********
The second 6000XP inverter I picked up will NOT update, keeps failing. The first time through it appeared to be stuck after about 30 minutes I rebooted the inverter, since then it will just fail to update from the monitor app webpage and I cannot get it to see any further trying to do it directly via dongle on phone etc. The inverter was working fine but I have to run identical firmware for two 6000Xp's in parallel. Anyone else had issues?
