I don't have a ammeter, so I just played with the number until the amps on the BMS matched the number on the LV5048.
Thanks for the info!
This is good one to set really low. I just discovered what it does after a months of use.
This keeps the cell difference from getting wide. During charging this can really be a headache if one cell zooms up faster than the others. I am pretty sure I 4 out 64 that love to be at the top of the V scale.
Last week I stumbled across it by accident. It forces the packs to stay together much better than I realized what was going on. Friday it kept shutting down after bulk charging finished, but what I now have also discovered, is that it is much better for top balancing.
My packs kept dropping to 52.9 almost instantly, but now they all held charge at 54.3, for 2 ½ days. Maybe dumb luck, but quite surprising.
Do you recommend leaving it at the 0.1v default setting?
Really glad you started this topic, I was wondering if I was the only one using the ant.bms most of the stuff on there leaves one lost.BYD Pack?
I set Bulk charge to 28V and Flow Charge to 26.8V
and that value does not alter any balancing behaviour, and I found 0.5V is the best so far for used packs.
New Cell? I think 0.1V make sense.
I am drawing 20A constantly (0.2C rate?) and charging via 1350W solar.
The default is 1.0!
I discovered its value when I set it at 0.08.
I have 0.10 the setting for now. But think 0.05 might actually be even better.
I don't know what this setting does or if it kicks in when discharging. Yesterday with 0.1 set, I ran all day zero problems.
Thanks for helping figure this thing out and dialing in these settings.
If you are going to have more than one ANT-BMS in your setups.
Do this 1st!
Change the Blue-Tooth MAC Address (3rd page down at least). Just anything else will work fine. As soon as you get the next BMS turned on, you will be able to connect to it. The button on the main screen that shows change mac, does nothing. Don't bother. Reconnect to the new blue-tooth to whatever new thing you find. Change the FE-LI button and then start modifying all the settings.
Some settings are very important for controlling cutoffs. Some settings are just for displaying amps and SOC and have no effect on the performance of the battery.
My present settings;
View attachment 6648View attachment 6647View attachment 6645View attachment 6644
Do this 1st!
Jason, I have my Ant. cell one showing .091 volts when the cell shows 3.28v I ordered a replacement, thinking I must have did something wrong, any suggestions the other 7 show normal readingsIf you are going to have more than one ANT-BMS in your setups.
Do this 1st!
screwed up cell 8 2 wires pin 17+18 I only connected 1 wire. that why my temperature was so off the supplier said must be the wiring,
best drill out the rivets re do.. live and learn
since China is still on Holidays, might be able to cancel
once I had them all riveted then neatly strapped into place tucked away. only to get the wiring could be wrong. oh well. was not the wiringMake sure the temp sensor wire harness is not the same RBY RBY. It must be RBY YBR.
good to know, still waiting for my replacements to be shipped from china.Ladies and Gentlemen.
The newly discovered most worst Chinese/English translation!!!
Max Balance Limit Voltage!!!!
No, that is not the top end of the voltage to start balancing, that is what the Voltage of the cell must be to start balancing!!!!
Holy freeholi!!
I had it set to 3.6V. I just changed it to 3.2, and just like that, every friggin cell started twinkling, aka balancing!
Now I have an active balancer!
What does Start Balancing Voltage mean to you? I have mine set at 2.95V.
