JBoffgrid2022
- Oct 28, 2022
- 153
Hello All,
Looking for advice on getting a heat pump for providing strictly AC (No heat) to our off grid camp. We recently installed the following setup and it has been working great so far. Ideally, I'd love a setup that could grab DC power from either my battery bank or solar panels. But if that isn't possible, does anyone have recommendations on a good, AC powered air conditioner unit that is less than 500 watts? I tried using a 300 watt / 5000BTU window unit last year but it couldn't keep our camp cool enough. Also, on sunny days, my current system will be able to put out roughly 28kWh-35kWh per day. The usage of the camp (not including any air conditioner/heat pump) will not exceed 5kWh on any given day which would leave plenty of power for a cooling system. Thank you!
Here is my setup:
EG4 6kW Off-Grid Split Phase Inverter (1)
EG4 LifePower4 Lithium Battery | 48V 100AH (4)
EG4 Enclosed Battery Rack (1)
SunPower 450W Mono Solar Panel (Silver) A-Series Solar Panel (16) 2S8P
TIGO TS4-A-O Optimizers with CCA
Here is my setup:
