They are in the wall.Nice....dumb question but wheres your outlets?
But i am still a little unclear. Perhaps you might point me in the direction learn about this or elaborate.Otherwise a 50 amp outlet and a 50 amp inlet should serve you well
The inlet would be for an outside power source. Usually this would be utility power at an RV park, a buddy's house, or possibly a portable generator. If that is not the intended use maybe a smaller and simpler inverter would be easier.I would like to have 12 total 5-15 outlets. I would like to go from AC-OUT to 5-15 outlets. You mention utility power, sorry but Im still getting confused by your explanation, what do you mean by utility power?
You suggest 12-2 Romex, which I believe is 12 AWG. Part of my confusion is that it says minimum 6 AWG wire. Nema 12 seems to be standard for outlets and such, the gauge are mismatch. We would like the abilty to go over 15A too.You could just take 12-2 Romex, wire it directly to the output terminal to an outlet, then daisy chain off it each outlet for your 12 outlets and then set the inverter for a max discharge of 15a and be done.
The 6awg it to take into account the full capability of the unit including the power assist feature.You suggest 12-2 Romex, which I believe is 12 AWG. Part of my confusion is that it says minimum 6 AWG wire. Nema 12 seems to be standard for outlets and such, the gauge are mismatch. We would like the abilty to go over 15A too.
