Jackel440
Good evening everyone,
I will lay out my system and then ask about my current issue
I have a 5th wheel camper that I installed a Victron Multiplus II 2x120 24/3000/70-50, Cerbo GX with touch 70,Lynx shunt and lynx distributer,
I am using 2 Redodo 12v 100ah batteries with low temp charge protection. No solar panels.
this system has been running for a bout a month in my rv and has worked flawlessly till now.
Last week we had high temps hit god old indiana and my ac in the house quit. So my wife fired up the air conditioning in the rv to help cool our golden retriever down. no problem, the air was on but she didnt know that both ac came on and would blow the breaker do to too much amp draw from the 20amp outlet on my shop. So it looked like the invertor ran the air on and off for an hour and a half before it shut down due to low voltage.
I got home and luckily the camper hadnt got too warm for Maverick. I reset the breaker and turned off the other ac unit. The Multiplus started recharging the batteries and all is well.
The nxt day or so I started getting Low voltage alarms from the Multiplus every hour or so. I found the lynx shunt was showing 26.64 volts but the Multiplus was saying it was reading 18.1v I checked the batteries with my multimeter and it was matching what the Lynx was saying.
I decided to check the firmware after trying to figure out why the voltage readings didn't match. I updated the firmware on the Multiplus and the Cerbo I think.
Now the Multiplus shows dc voltage fluctuating at 26.97 to 27.02v
it is in float mode but the battery says "idle" and is greyed out on the touch display
The Lynx shunt shunt shows 26.54v 0.0a, 0w
the Multiplus will pass power through like normal but will not charge the battery or use it to supplement or just invert without a/c input.
I have checked all connections to make sure they are tight. nothing is loose or running hot.
I'm a millwright and not an electronics guru but I do love this stuff and have been learning a lot during this installation. Things have been great till now and I just need to figure out what needs to be done to trouble shoot to find a solution to my problem.
I have sent an email to the battery manufacturer about what I need to do to check and verify the battery condition. They were awesome to respond with other questions I had during my instalation. So I hope to hear from the tomorrow.
Any ideas or suggestions are appreciated and I will try to walk through them best I can.
thanks everyone for your time
