tomy2
escape artist
It started with a shock from the metal conduit between the roof solar panels and the inverters. The conduit surface reads 170 volts AC., not good. There are two EG4 3000 hybrid inverters connected to a load panel split phase. and another sub-panel 60amp two phase breaker supplying grid power to the inverters. Four 48V 100amp hour 3G4 batteries too. there are 8 400-watt panels feeding each inverter. The multi-meter reads 170 volts AC at the solar cable inputs on both inverters with the solar disconnected, even with the 60amp input breaker off. I double checked all the wires feeding into the inverters, no problems. The grounds to and from the inverters are good . I sent pictures to SS and am waiting for a response. Maybe someone has seen this before, and can help. My limited electrical ability is at a loss.
