6/14/23
Hi,
I am getting a "ACr error" on my Renogy MPPT 40 Controller.
I am having a problem solving this... any help would be greatly appreciated.
I recently finalized set up, and it was working great... Then I tried using my giandal 3000 inverter to heat my Bosch 4 gal water tank. After 10 minutes the inverter got a "fault" error. I shut it off. After that I am now getting the "ACr error" on my MPPT controller.
I also have a Victron Battery Monitor connected to the battery bus bar. It reads 100% charged.
According to Renogy the ACr error indicates that the PV is maybe not connected correctly... but it was working properly before, so I dont think that is it. Here are the trouble shooting notes from Renogy:
Cause 1: Break in the Circuit
I used a multi meter and my batteries have 14.5v. and my MPPT battery connection reads 14.5v.
My MPPT PV connection is not getting a reading... its "L" low. Its cloudy today, so is that why no charge is coming in from the solar panels? ie., this is a normal read?
Cause 2: 12V Lithium Incorrectly set to 24V on Controller
My controller settings are correct... 12v and Lithium batteries
Cause 3: Your Demand is higher than your Lithium Battery Capacity
Demand is really not anything at the moment, though I was running a 12v Whynter frig for a few days just fine before this event, when things were all working fine.
Cause 4: Lithium Reverse Polarity w/ Solar Connected
I rechecked the lines... I believe the solar is connected correctly...
This is what my set up includes:
- Renogy Li 40 Amp Rover MPPT Solar Charge Controller
- 2 x Renogy 200-Watt 12 Volt Monocrystalline Solar Panels
- 3 x Renogy 12V 100AH Smart Lithium Iron Phosphate Batteries
- Giandal 3000W Pure Sine Wave Inverter
- Victron Lynx Bus Bar
-Victron Battery Monitor
I will attach some general wiring photos in case something stands out as a problem.
Any help is greatly appreciated.
Also, does anyone know of a solar specialist in the Portland /Vancouver Metro area they can recommend?
Thanks!
Hi,
Thanks!
