george_fry
Morning All,
Hopefully someone can help.
In August I Purchased Solar Panels (200W 12/24v monocrystalline solar premium kit with rover 20A MPPT controller and a 170AH lithium battery from Renogy (Along with a smart shunt and DC-DC Charger from Victron) . I installed these items into my camper van. Back on the 28th January I noticed that my controller was saying ACR as an error message. Following this I turned off all my 12v power and it has been off since then. Since that day I haven't driven my van.
My van then went from ACR to
Error E1 (Battery overdischarged)
Solar 20.5v
solar amps 0
Battery 0%
Battery to fuse 0 Amps
solar to battery 0AH
Battery to fuses 0AH
On my victron smart shunt i was getting
11.21V
0A current
0W power
I used a multimeter to check and the solar and i was getting 20V going into the MPPT and 11V going out of the MPPT
Then a couple of days later my solar was starting to get AMps but it was cutting out when it got to approx 0.69A
The voltage on the battery was going between 11.15V and 11.75V but I am unsure as to why this was changing as everything is disconnected from the battery output ?
also the battery % on the MPPT has been changing between 6% and 15% at this point. Since then it has been to 30% all the way to 100% and all the way back down to 0%
Since this point the error codes went entirely for a short period however then went to E3 (Battery Under voltage) back to E1 (Battery over-discharged) and now it is back on ACR again.
I have contacted Renogy multiple times but am struggling to get any answers and after almost 2 weeks I was hoping someone on here might be able to help me ?
Many thanks
George
Solar 20.5v
solar amps 0
Battery 0%
11.21V
0A current
0W power
Many thanks
George
