Soo...
I have a 370 AH string of six Trojan L16's,
I bought them used, they are currently 10 years old and provide yeoman service.
Resting voltage on the string (after charging and sitting 24 hrs disconnected) is 50.4 volts.
Currently they carry the required load for around 15 hrs and then my Radian switches to grid power if sun is inadequate.
I found a good deal on new L16's and picked up another 370 AH string, I would like to parallel the original string, .. from what I read the reduced capacity of the old string will drag down the new string...
Is there any scheme where a large diode could be used as a blocking diode to prevent this? or a Arduino controlled contactor to tie the two together when capacities are matched?
