Add switch/relay to control QNBBM active balancer
Tobi17
Hello,
two questions:
1) Does anyone have add a switch/relay on the minus pole on the QNBBM active balancer to control it? I do want to add a switch and/or relay to be able to control the unit. Since you connect one negative pole and all positive poles, surely it is required to control the negative pole. Does the balancer allows this and would this work as intended?
2) If I add an ampere meter on the minus pole as well, would this get the total ampere the active balancer is transferring? I would guess this would be correct way, but I am not sure if this really 100% right.
Your feedback would be much appreciated, thank you!
Bye
Tobi
