I have a 24v nominal battery made of Headway 10ah LFP cells, and despite taking care to make sure the parallel strings are all roughly the same capacity, I'm finding that a few strings dropping in capacity much more quickly than others, not always the same strings.
The BMS is a JK with 2A active balancing, but it doesn't seem to be able to keep up too well especially at the top/bottom ends of the curve.
Is it possible to add a second active balancer to the setup, or are there known issues with that approach? Would that help keep the strings in better balance, leading to more output between LV and HV cutoff points?
