Battery active balancer - extra balancer in på with JK BMS 200A 16s (non-Inverter model)
I think I have a battery that is quite problematic to charge and holds the other battery back. One cell constantly hits OVP early on... Now I'm trying to add inverter communication to the jk bms, but that won't change the physical issue... One battery will always hold the other one (or several other) back.
At the same time retrofitting another balancer into this battery will require some non-trivial mechanical reworking. Which might actuly require to transplant the cells into another battery box anyways...
At least for the future batteries I'm currently building, I think it's therefore a good idea to include an extra active balancer PERMANENTLY connected.
What are good options (ideally up to 10A real no matter what the voltage difference is, I. E. not only 10A with 1V difference etc)?
- JK-B10A24S not manufactured anymore?
- NEEY???
One must-have feature is the ability to set the start balancing voltage (I use 3.45V based on Andy from off grid garage), not to let it balance all the time.
Thanks for the help 😁
Neey will tick all your boxes
I'm not sure 6A vs 2A will even be enough to be honest.
Right now the jk bms is struggling.
But is the 4th gen NEEY using the average (like the 3rd gen in Andy video from off grid garage) or the maximum cell voltage to start balancing ?
I only use 4a 4rth generation.
You can set start, stop and volt difference as parameters without issue
Yes but for the start voltage... Does it use the average or maximum cell voltage to start balancing?
3rd gen had a "feature" (I'd call that a bug) that only if the AVERAGE cell voltage was above the start balancing criteria, then it would start balancing.
It should be the MAXIMUM. But I didn't understand if they fixed that in the 4th gen...
Maxium
I also got to build 2 extra soon... Need to figure out where to put the NEEY on these and probably will have to think about retrofit later to the other batteries 😔
I use a 3d printed holder, that I bold on to the pressure plate, middle screw
Leaves plenty of space for the BMS and cooling, but prevents stuff moving around
I was thinking for the new battery of some plywood mounting plate... Old battery probably hanging somewhere... Aren't there some screw holes on the back of the NEEY?
The jk bms also has some tiny screw holes in the back...
