silverstone
- May 3, 2022
- 1,041
I also got to build 2 extra soon... Need to figure out where to put the NEEY on these and probably will have to think about retrofit later to the other batteries
I use a 3d printed holder, that I bold on to the pressure plate, middle screwI also got to build 2 extra soon... Need to figure out where to put the NEEY on these and probably will have to think about retrofit later to the other batteries
I was thinking for the new battery of some plywood mounting plate... Old battery probably hanging somewhere... Aren't there some screw holes on the back of the NEEY?I use a 3d printed holder, that I bold on to the pressure plate, middle screw
Leaves plenty of space for the BMS and cooling, but prevents stuff moving around
There are not..IAren't there some screw holes on the back of the NEEY
I guess I'll use some 90° bracket and / or cable ties then.There are not..
Closed little box
Used Velcro in the past, but eventually they would come loose
Looks neat. Is it yours? I don't have a 3d printer though...Neey balancer wall mount with vent by Tueftler_
This is a wall mount for the popular Neey balancer of e.g. LiFePo4 cells. Included air ventilation openings. Easy to print. Have fun of printing that!www.thingiverse.com
No, but this is what I use.Looks neat. Is it yours? I don't have a 3d printer though...
Don't know these, so couldn't tell you how and if the jk worksOtherwise this one with mounting bracket from jk bms? Not sure about the settings etc though
B1A16S B2A16S 1A 2A 5A 10A Li-ion Lifepo4 JKBMS Equalizer with BT JK-B1A24S JK-B2A24S
Is this where you got your NEEY from ?Don't know these, so couldn't tell you how and if the jk works
So Hankzor Shop is trustworthy ? There were a couple of bad reviews for Hankzor (but then again 2 bad over 100, the other shop was 2 positive and 2 total - not much to go by)bought for both ..
hankzor the last couple of times
had my 2 last ones in 5 working daysOK, bought 2 NEEY from Hankzor Shop. Let's hope for the best. Apparently they are in stock in EU warehouse (Poland) so it should arrive quite fast ...
It arrived very quickly ... Now to figure out how to mount it.had my 2 last ones in 5 working days
I see for instance PCBWing is offering some 3D printing service which doesn't appear to be that expensive (~15 EUR / each holder). And there were a few 3D stl files on thingsverse and similar sites. But of course it's probably another case of the shipping/VAT/duties costing more than the product itself ...
But I now have a separate question ... Protection wise. In case of internal fault to the NEEY (e.g. Blown Supercapacitor, Blown MOSFET ending in short-circuit, ...) what is in place to prevent the whole battery to go BOOM ? I'm especially worried about failure modes resulting in Cell Overvoltage and Cell Undervoltage.
Depending where you put your NEEY (on the battery side or inverter side), either way, the NEEY power supply is derived either internally (from battery itself) or externally (from another battery, charger, or inverter). And even in case of BMS disconnection, it would still get the power either internally or externally.
AND, even if power supply is cut off, due to the internal failure mode described, I am not so sure that it still will not result in a huge disaster.
I already have fused terminal blocks in place so I would *hope* (not a good design ...) that in an event of blown capacitor or MOSFET in short-circuit you would get enough current (> 10A) to melt the fuse quite quickly (on the individual balance leads), as the NEEY would have then "lost control" of the power electronics.
The other option was to cut off the Power Supply using a Contactor or Shunt Trip Unit for a Breaker.
Any ideas ?
So it is already fused ? I didn't know that .? What are you talking about? Look at the bottom and tell me what are those tiny little things near those wires.
Yes....JK-BMS and NEEY/ENERKEY have fuses on each sense/balance line. If it is blown, you gonna need a good soldering skill to replace it.So it is already fused ? I didn't know that .
Do you know the specifics of that fuse ?
I also fused the JK BMS Leads for that matter. You are going to tell me those are also already fused ?
Well, I guess the external fuse is still good practice to protect a fault on the wire itself.Yes....JK-BMS and NEEY/ENERKEY have fuses on each sense/balance line. If it is blown, you gonna need a good soldering skill to replace it.
Even Heltec 5A capacitive active balancer have fuses on each lines.
However....you need to beware of certain Heltec 5A look alike clone, these clones don't even have fuse at all.
