silverstone
- May 3, 2022
- 1,041
I think I have a battery that is quite problematic to charge and holds the other battery back. One cell constantly hits OVP early on... Now I'm trying to add inverter communication to the jk bms, but that won't change the physical issue... One battery will always hold the other one (or several other) back.
At the same time retrofitting another balancer into this battery will require some non-trivial mechanical reworking. Which might actuly require to transplant the cells into another battery box anyways...
At least for the future batteries I'm currently building, I think it's therefore a good idea to include an extra active balancer PERMANENTLY connected.
What are good options (ideally up to 10A real no matter what the voltage difference is, I. E. not only 10A with 1V difference etc)?
- JK-B10A24S not manufactured anymore?
- NEEY???
One must-have feature is the ability to set the start balancing voltage (I use 3.45V based on Andy from off grid garage), not to let it balance all the time.
Thanks for the help
- NEEY???
Thanks for the help
