Danimal86
I'm kicking myself in the butt for not maxing out our solar option back in 2016 when our house was being built. The builder installed a 2kw (i'd have to dig up the paperwork to confirm) system that uses a Sunnyboy SB 3000TL-US-22 inverter and 5 panels on the roof of the second story (west facing). Looking at the sunpower app, we usually generate around 0.9kwh at peak during the day (this is August between 2-3pm). Seems like there's a lot of room left on the table.
I was looking at the data sheet for the inverter and saw that it has two inputs.
I'm not comfortable going up on the second story and messing with the roof, but we have a alumawood patio cover that starts getting sun around noon (back side of the house, west facing) thats about 25' wide and 10' deep.
I'm always looking around facebook marketplace and i see used panels for fairly cheap. For starters i'd add around 1k - 1.5k of solar to the system, figuring that that would get me around 2kwh production in ideal conditions. Most likely, since i'm a tinkerer....i'd keep adding until i get to the 3kwh.
Seems like i'd need 3-5 panels to get me going depending on the Vmp of the panels to get me over the 150v start voltage. Sunpower panels seem like they have the highest Vmp, i have local people that sell 320w sunpower panels for $100 (Vmp 55), so for around $500 in panels i could probably be close to my goal of 2kwh.
As far as the installation and connection, i'd probably use some sort of a track for the panels on the patio cover so that the weight would be distributed evenly (dont want to exceed 200lbs) and i probably will just leave them up for spring through fall and then take them down for winter since it can get pretty windy here. For connecting to the inverter I was thinking about adding a dc rated breaker inbetween the panels and inverter. Not really sure about how i would run the wires, probably try to have some sort of shielding on them but would rather not run conduit on the side of the house. I guess then just connect it to the second MPPT. Seem reasonable?
I'd love to hear some input if this seems like a good idea or i'm off my rocker. I'm also a little concerned with NEM 3.0, i'm not sure how anyone would know that we've added solar, we never dip into the negative for power usage.
