GXMnow
Solar Wizard
- Jul 17, 2020
- 2,715
Does anyone on here have a Schneider Conext Gateway? And if you do, it is connected WiFi to your network? I spent about an hour with the gateway, and I have it updated to the latest 1.08 software. I think I have the WiFi configured correct, I picked my network, entered the WiFi password, and it lit up a nice green check mark. I have it set for DHCP, but I can't see it in my router log. I have tried several things, even having it full reboot without the ethernet cable, and it still is not asking the router for an IP address. As soon as I plug the cable back in, it comes up and works fine, but I was hoping not to have to run an ethernet cable out to the far end of the garage. So I have not even added the XW-Pro to my plant yet in the gateway, and have not even seen the setting in the inverter yet. When I am a bit more awake, I will just take my laptop in the garage so I can get the Gateway connected to the XW-Pro and at least configure it for my battery bank before I let it charge at all. I need to also go pickup a couple more conduit fittings and #8 wire to tie it in to my breaker panels.
With just the battery bank, it lit up in standby mode. I hit the power button and it turned on and was making the 120/240 split phase power (it measured 118/236, close enough) and pulled just over 1 amp from the battery in run mode. When I went to shut it down, a tap on the power button did nothing, so I then held it in and after a few seconds, it did shut off. But as I went to turn off the battery disconnect, it powered back up again. It did not want to stay off or go into standby. I am sure that has to be a setting. I finally held the button in and when the BMS showed zero current and the face of the XW was dark, I shut off the battery bank disconnect. A few seconds later, the XW still tried to power back up, but the caps only lit it up for about 2 seconds as the fans cycled and it went dark.
After some breakfast, I'll be back at it today. I guess you could say there is one good thing about this Covid-19 lock out. I am working from home and as long as I keep my reports getting in on time and I monitor my phone and e-mail and deal with customers, I am here to work on this. But I would so much rather be back at work. We all really need to wear our masks and do what we can to slow the spread.
