I installed a AIMS 2500w Inverter/charger/transfer switch unit in my RV and it blew the 250amp bolt on fuse I had on my new Fortune 100ah lithium battery. I was connected to shore power and running the AC and it had been running for about an hour before it blew. I thought that was odd since the only thing that should have been going into the battery was around 50amp from the charger. It is a 85amp charger but I have it turned down since I only have a 100ah lithium battery bank. So, 50amps is far from 250amps. I thought maybe I had a bad fuse so I replaced it and it blew again within an hour. Then I thought maybe the AIMS transfer switch was not recognizing the shore power and was trying to run my AC unit via the inverter. I couldn't test this since that was my last spare fuse. Also FYI I did have my Progressive Industries surge protector on the shore power pedestal and that was reading all good. So, I called AIMS and the tech said to just up the fuse to 300 amp. Wait, that does not sound right. Why is the unit pulling or pushing that many apps to/from the battery in the first place? The tech refused to address that and just keep saying up the fuse size, that I would be fine then. Am I missing something? Thanks all
