Yes linked earlier… comical. But a good testament to the system if when used as designed with proper weight and spans. I am amazed big system lasted that long ….it weathered several storms according to him. He showed in a video during bad storm- did alright .
Be nice to see someone setup fixed array near a tracker and compare. Same basic panels. One tracked one fixed.
I see these being great for someone small space. Someone that needs panels remain optimal angles max production. Still messing around not got my tracker up. Wrecked my back. Raining a lot too.. power on and off modem on and off on reset.
I found some 650 watt panels for cheap….. 6 x ~650w = ~3900watts around ~26ft run for ground mount. ~$930-~$1000.
I had a 20ft shipping container coming was going to mount panels to it. Top and sides. The seller never communicated back when asked if hazardous materials had been in container …. Hmmm …. So still looking. That seems to be a spooky question to ask container sellers.
Anyway been playing with panels on old pool deck…. 2 each old 325w poly panels will kick the crap out of 4 each ecoworthy 195w bifacial panels. Crazy. Those poly panels are rough shape too. They - poly panels pull ~625w + in series. The 4 each eco 195w pull around ~525-575 or so….on a real good spring day ..once or twice 600w range. Never 780w rating…. Or higher from bifacial. They be fibbing. I was hoping the former pool sand would help ecoworthy bifacial effect. Kind of shocked me for performance that old dirty poly performed so well. Not impressed with ecoworthy.
The ecoworthy are extremely light weight ~20pounds. All 4 eco are about same voltage ~23vdc. I considered popping 2 each ~650watt bifacial on mine to-see how it would do. 6 x 20 = 120pounds.for Ecoworthy
The 650w are 2x~75 = 150pounds they are ~ 94”x51” The tracker is ~117” span. Can tracker take the extra weight of additional 30 pounds? Guy in video over loaded it for big one by about 3x considering the span and weight. One time it looked as if dragging ground on a corner.
The ecoworthy ground mounts were on sale for $89 with discounts got 3 of them…. They need to be reworked - for heavier panels Even with just 2 the Ecoworthy ground mount is flexing and bottoms are touching deck so ran with them touching deck to support weight. The ground mount works like a champ with ecoworthy panels locks together form strong system. This is only temp. The old poly kick butt. They were cheap but are heavy. Btw notice the light - sand on other sides of eco panels that should help bifacial tried get them on edge of old deck allow max light on back.. The cheap bifacial are Pitiful.
Any idea why the poly are doing so well?
Eco ~143w a panel for ~195w bifacial
Poly Wash and cleaned into ~600w range everyday.
Poly ` `316w per for 325 watt rating.
