Can someone tell if I have it right in my mind- I am building four sets of 4x3.2v300a battery each with its own 200ah BMS. Eventually, I want to build up to a 14Kw battery backup for an off-grid power (Battery) supply for my new house. Right now I have 28 x 280W (32V) Poly solar panels. Currently, I am consuming between 1450-2300wats per hour during the day and 480-1100watts at night after dinner. I want tho have as much amperage as possible that is why I am using 3.2v300Ah Lithium Phosphate battery cells. During summer we use up 9-11Kw of power however my current system produces 22.5kw per day and this goes back into the grid through a Fronius Grid-tied Inverter for which I receive very good money from the power company.
My question is I where can I buy a Hybrid Solar charge 12-24 -48volts inverter to give me 240VAC at 100 amps.
All I see in the market place are 48V inverters at that amperage. I want an MPPT Hybrid solar Charge inverter that can receive 12-24-48 volts from the PV array without cooking itself out of existence
I do not want to sacrifice my amperage and run the 12volt batteries in series and cut my power by using 24 volts or worst 48volts The way I see it it would be a waste of money to drop my amperage because of the inverter. If I use 8-9 Batteries 12v 300Ah I can achieve 10Kw or 12 batteries will give me 14Kw. The cost of wiring is not an issue because the inverter can be withing three feet of the Batteries bank. From the inverter goes to the house in 100 amp standard wiring Someone out there may be able to help me out please
