My RV will have a solar controller mounted in it to charge the batteries. I will not have an inverter, just 12v stuff. The solar panels are going to be on a separate trailer. Eventually the RV will be connected to a different ground Mount system at our property. I'd like to be able to just leave this and the solar controller would stay with RV when go on trips. I was thinking have a one foot piece of wire coming out of the solar controller to an Anderson connector and then the Anderson connector to the power wire from the combiner box coming from the solar array. Of course when I connect and disconnect it, I would first disconnect the breaker at the combiner box but I'm just wondering if the Anderson connector is a good way about going to have a quick disconnect option for the 3 panels. 30v x 3 = 90v max 38v x 3= 114v from panels at 750w to the controller for a 12v RV system.
Thanks for your opinions guys!
