With the added capacitors, I used different resistive loads and here are the waveforms of the 220vac output.
Update:
Started load testing using a 7.5KVA resistive load, connected the 'scope at the 220vac output and observed that it is noisy. This is is with the existing 2.2uF capacitor at each output phase of the split phase toroid transformer.
Thanks, if it affects the loads I will add similar power line filter and/or do some tuning of the toroid/inductor/capacitor combination. If I remember, warspeed suggested to tune it to 1.5 times the line frequency.Capacitor across output, so only "L" is parasitic of the low-frequency transformer (and maybe boost inductor)?
Explicit "L" may help. Or a leakier power transform instead of that nice toroid?
We're wrapping up a project using TDK/Lambda PFC module. No eval boards were available, and their test circuit used custom-wound inductors on commercial cores. We selected off the shelf common-mode chokes for input and output filter. The differential mode inductance is whatever leakage inductance it has.
But we had about 125 kHz switcher, so smaller filter works. I think your switching is about 1/10th of that.
The module we bought is 1.5kW, and our application is only half that, so smaller components than you would need.
(and ours is 360VDC, so low current.)
Something similar to these. It did do a decent job of cleaning up the switching current.
It also suppressed 120 Hz component (which we care about) somewhat, but being single stage boost, still has a discharge across the low voltage time of each 60 Hz cycle. Would need a buck stage as well to suppress that, or 3-phase PFC implementation.
We measured efficiency and power factor around 95% and 0.95, in line with vendor data sheets.
Included in the edited post, will add air inlet and outlet ports. Thanks for the reminder.Ventilation?
Something like an inverter will expel hot air, and recirculate back to it's input.
Separately ventilating enclosure should help, but interior will run hotter than exterior.
I would prefer to exhaust hot air through duct to outside the enclosure.
Nice and neat arrangement.Hello everyone, congratulations for the great work you have done.I limited myself to taking a Chinese 24 MOS module at 48 volts, two 3000 VA toroids in series with 11 + 11 primary turns of 35 mm2 and 230 volt windings in parallel.It has been working for about 4 months and has delivered 1200 kW without ever a problem. With a two kW load it has an efficiency of 95% tested up to 5.5 kW.my main fear is the 80 volt hy4008 mosfets and the batteries go up to 56 volts...for this reason I got a similar inverter board but without mosfet to do some tests, if anyone can give me some advice on the choice it would do me a great favor.
I attach the photo of my work
best regards
Mauro
I think you might need at least two of those in each leg, or eight or twelve total for 90 amps dc, it should work.Do you think it's worth trying them or getting something else with less RDSON?
