Filter inductor core is saturating as 60 Hz load current increases.
The 60 Hz low freq current is like large DC bias flux on filter inductor core saturating it. When it approaches saturation the effective inductance plummets reducing the high frequency PWM filtering. This is why the HF ripple increases at peaks of 60 Hz waveform where the 60Hz current is greatest.
Core size and number of turns flux density must stay out of saturation for the peak 60 Hz bias current created core flux.
Suggest using
Mega Flux Cores.
Design info at:
Coil Winding Specialist, Inc. : Data on MPP, Sendust, and High Flux Cores. - Products Specification & Properties About Us LOG IN HOME Other Services coil, ecommerce, open source, shop, online shopping, store
www.cwsbytemark.com
1) Pick a core.
2) Calculate number of turns required for PWM frequency filter inductance.
3) Check flux density (amp-turns) from charts for selected core saturation at peak 60 Hz current (plus some margin).
4) If too close to saturation, select a larger core and repeat starting with step 2.
5) Determine wire gauge to handle peak 60 Hz current
6) Check if required wire gauge and number of turns fits on core. (You can use multiple parallel smaller gauge wires to accomplish 60 Hz current handling).
7) If not, select a larger core and repeat starting with step 2.
Core material selected should not be too lossy at PWM frequencies.
Improper PWM L-C filter design is one of the primary causes of excessive inverter no-load idle current. Low reactive loading due to PWM filtering increases inverter idle current. Higher impedance L-C filter (more inductance, less capacitance) reduces idle current but the inductor core must be larger (and more expensive) due to the greater amp-turns of filter inductor to prevent core saturation under peak low frequency AC load current.
For LF inverter designs, the PWM filter is usually done with inductor in series with high current primary and capacitor placed on secondary side of LF transformer. On first approximation, the design of PWM filter can be modelled on primary side, then capacitor impedance transformed to secondary side of LF transformer. The LF transformer is not perfect for HF PWM frequencies but is usually acceptable to approximate as an idea impedance transform that reduces the shunt capacitor value on secondary side of LF transformer by the turns ratio of LF transformer.
