manly
- Jun 23, 2021
- 49
My capacity tester is reading less amps than my Overkill Solar BMS says is being taken.
I took some pictures as an example. This is a 12v, 280ah battery. The BMS showing 7.7 amps being drawn while the capacity tester shows only 7.03 amps being drawn.
Doesn't seem there shouldn't be that much drop through the wires, and all the nuts are tight. Scratching my head here... any ideas? It did the same thing on the first battery I put together (cells 1-4). Capacity tested at only 243 amp-hours.
