The oil fill does seem like an interesting and practical idea. Recommendations on which oil to use?
Oil in transformers degrades due to partial discharge (solid dielectrics can have same problem), but I don't think that will be the case for these relatively low voltages.
The SF6 I suggested should work, but it is getting restricted as a global warming contributor. For 11,000' operation, air pressure is about 65% of sea level, so "clearance" distances would need to increase 50% to maintain same point on the pressure x distance axis of Paschen curve (number of atoms or multiple of mean free path between electrodes.) Easy enough design parameter if considered up front, also some IC packages might be a problem.
SF6 is used in pretty extreme high voltage situations. Nitrogen and air (of which it makes up 78%) have same Paschen curve. Of several common gasses, N2 has highest withstand voltage for a given pressure x distance product:
en.wikipedia.org
SF6 is better than air and N2, but not by as much as I expected. 2x the voltage at lower pressures, 3x at right hand side of chart:
Fig. 1: Measured and calculated Paschen curves for air, N2 and SF6 - "Analysis of Paschen Curves for air, N2 and SF6 Using the Townsend Breakdown Equation"
www.semanticscholar.org
Was thinking some other gas would be suitable, but haven't found one.
Several of the popular refrigerants are mentioned. Need to find Paschen curves for them:
en.wikipedia.org
R134A has 85% the dielectric strength of SF6:
There, maybe I've found a $20 fix for you.
Crazy enough for you all? ?
