What are the exact needs? Split phase (probably not as the Outback was 120V), surge capability, daily usage,mobile or stationary and size of battery bank?
it's mainly backup power (especially in winter when production is lower) but in summer, i would switch as many loads over as i could when i had plenty of excess power. it's an expensive hobby as my total usage on grid is about 5kwh/day - so it's not saving me much to run it instead of the grid. i don't need 220v (though some day it would be nice to run the well pump). the only other 220v appliance is the oven. the fridge uses 1kwh/day. other appliances such as PC, tv, router, modem - probably use about the same combined. so the actual power requirement is small. 3kw inverter would be more than enough. battery bank is 10kwh lifepo.
