Dinobot248
Are there any inverters (AIO or piece meal approach (Victron?)) that have a programmable SBU function?
I know the question is vague so here is my use case. I want my system to run on solar, a certain amount of battery, and utility covers the rest.
For example, there is a 6kw load ( eg dishwasher, microwave, blow dryer are causing the short term spike in use)
1. Solar supplies 1kw
2. Battery is configured / programmed to supply max 4kw
3. Utility supplies the rest 1kw
Normally the combination of Solar and battery is sufficient to cover nearly all loads.
My reasons are
1. Battery does not drain down to empty level before the next day. System does not shutdown.
2. I can leave town for a week and not worry as much about “Murphys Law”
3. If the a grid account is required for any reason (local ordinance, convenience, etc) might as well make use of it.
4. I can reduce my battery bank size.
5. I can get better utilization of my system eg shift batteries or PV over to another place. Maybe quicker ROI. Maybe get a better inverter while I am at this.
I read the Solar 15k and watch how Victron power assist work. Both appear to treat the grid as your primary power source. Solar and/or battery can be configured to supplement and covers any peak demand.
I want to treat Solar and battery as the primary power source and have the grid supplement when necessary.
I thought about maybe having two inverters connected say two 5k Quattros. It gets kind of silly to have one inverter act as the grid for the second inverter.
My reasons are
