btmurrell
Just watched Will's great review of the Li Time 12v 100ah trolling motor battery w/ temp protection... I am trying to find a reliable answer to the question "Are trolling motor batteries well-suited for Vans or RVs?" Can someone with knowledge, experience, or resources help?
ChatGPT tells me no:
RVs typically use deep cycle batteries or a bank of deep cycle batteries as their primary power source. Deep cycle batteries are designed to provide a steady amount of power over an extended period of time, which is ideal for RVs because they need to power various onboard appliances, lights, and systems when not connected to shore power.
Trolling motor batteries, on the other hand, are designed to provide short bursts of power for trolling motors used in fishing. They are not well-suited for the continuous and sustained power demands of an RV. Using a trolling motor battery as the main power source for an RV would likely result in frequent discharges and reduced battery lifespan, as it may not have the capacity to meet the RV's power needs.If you are looking to power an RV, you should invest in high-quality deep cycle batteries or consider alternative power sources like generators or solar panels, depending on your specific power requirements and usage patterns. These options are better suited to provide the consistent and reliable power needed for RVs.
