Hi Folks. New member here.
I'm seriously looking at changing my AGM Group 31 batteries I've had wired in series (3 x 12) for a 36volt MinnKota Trolling motor.
It works well; but the weight of the 3 batteries (71# a piece) is over 200#'s and sometimes when trolling with wind, I end up running the batteries down to 25%.
I've had these AGM batteries for several years and I'm starting to see a little age on these as they don't last as long as they use to when on the boat all day fishing/trolling. So I'm looking at replacing them in the near future. I figure I'll go LiFePO4 so I get a bigger discharge cycle and reclaim some weight with lighter batteries.
The new SOK Marine 100Ah looks like a good fit as it is actually dimensionally a little bit smaller than my existing FullRiver AGM (DC115-12) batteries.
The storage compartment can only hold (maximum space) of 3 group 31 batteries. So that is why I'm looking at the 100Ah batteries and not the bigger marine battery that they make.
So my questions:
1. Has anyone torn apart the new SOK 100Ah marine battery? I assume its watertight with the plastic case...so any water splashing (specifically salt water) will not harm it. Does it have wire jumpers for interconnecting the cells? Or is it a copper bus bars?
2. I have a 3 bank Minn Kota Charger (MK3300) that does 10Amps per bank. Any concerns about using this charger for these LiFePo4 batteries?
Do I need to equilize the charge on these batteries before use? Or can I let the Minn Kota charger deal with it since it is a 3 bank charger and would charge each battery as needed?
Thanks!
So my questions:
Thanks!
