secondhandluck
- Jun 20, 2020
- 13
I am currently designing a system, that was originally intended to be strictly grid tied. I do have the panels and mounts for 3 strings of 8 Sunpower 305 panels, and they would work perfectly with a SMA SunnyBoy 7.0. It has three MPPT inputs, and their voltage limits work perfectly with my panel output.
But, I am having second thoughts and am considering a hybrid inverter, for the battery backup more than anything. So, after looking around this opens pandoras box, and I have more questions than answers.
The issues at first glance:
1. Many are limited to 48v DC input. I do like the Schneider Context 6848 as it can be configured for many battery types, but my panels are 58v so it's a no-go.
2. Many are built to work with specific batteries, which are out of my budget. For instance, the Solar Edge is made for the LG battery, and the Generac units only use the Generic batteries. I have the ability to purchase Trojan lead/acid for cheap, and would prefer that over a 6k Li battery.
3. Number of MPPT ports, The SunnyBoy 7.0 has three MPPT ports rated at 600V/ 700V max but I haven't found any Hybrid Inverter that is comparable.
I'm limited by what I can find searching through catalogs online, and staring at spec sheets, which is a lot of info but I'm sure I'm missing something. If anyone can point me towards a suitable hybrid, I would be most grateful.
FWIW, this system will be mounted on my barn roof here in S Jersey. I have been collecting bits and pieces for about a year, and just scored the panels and mounts. While I'm doing this cheaply, I am committed to buying the inverter new. My background is construction/ welding/ mechanic so much of this is familiar. I've helped install a few systems, but this is my first from start to finish.
Let me know if I've missed any important info that's needed, and thanks in advance.
SD
SD
