Vigilant24
- Aug 23, 2022
- 119
My planned system is a small, cheap minimalist one for emergency residential loads. Two 12V FLA marine deep cycle (well, kind of) batteries of 105 AH each, so approx 1300 Wh (to 50%DoD) to 2000 WH (80% DoD) of usable capacity. I anticipate years of on-grid float charging with no use, and would like to be able to count on them for 6 months (200 cycles) of heavy use.
Two situations:
1) "Storage": I understand that it's important to keep them at/near 100% capacity during "storage", with occassional desulfation/rebalancing. If I have a good charger that does the "floating" all the time and the "desulfation" on a monthly basis, is adding water all I need to do in addition to that? Should I draw them down 25% or so a few times a year to keep them healthy?
2) Hard use: If I need to use them (50% DoD every day or two), I'm not sure I'll be able to get them back up to 100% with the available solar power that same day. I can probably plan so that the bulk charging is done (to approx 80-90% full) but could run out of sunlight hours before getting to 100%. I'd expect to complete the absorption charge the next day. Will I lose capacity if my batteries frequently remain at 90% charge overnight, or does it take more than 12 hours for the "hard" sulfate to form on the plates? I've read that getting them back t 100% is "critical" (??timeframe??), then elsewhere I see that they shouldn't be left at less than 100% charge for "more than a week." Topping them off every week should be no problem, but getting them there daily is a bigger challenge.
Thanks for any assistance.
Two situations:
