Goboatingnow
- Jul 3, 2022
- 1,325
Must have a look again , big dealer near me is a friend. Most common ive seen in Audi is Bosch s5008;Audis use agm batteries.
Isnt that typically only on start stop ,I never designed for start stop cars.
Nope. I've been working on old tech trucks and they've had the sensors since I started back in auto in 2013.Isnt that typically only on start stop ,I never designed for start stop cars.
Probably in a roundabout way. Among other benefits, many AGMS do not have a charging current limit and can be brought back up to full charge quickly without such a strong impact on battery life.Maybe AGM is a start stop thing
Optimas in particular are usually double the money of the flooded equivalent, and rarely last twice as long, making them more expensive over time. So it is usually true that an AGM starting battery in a car is... reasonable.. justifiable.. but not cheaper in the end. It just reduces the frequency of your battery replacements in return for more up-front dollars.
By extension, this is also why the Walmart $64 value batteries are probably the cheapest over time. They cost about half what the 'regular' line costs, but in all likelihood probably last longer than half as long. Making the cheapest battery up front, also possibly the cheapest over time.
I'll elaborate since "garbage" isn't particularly descriptive.
Direct experience with several dozen 12V battery maintenance events with the 04-09 Prius yields the following:
In Phoenix, AZ:
Yuasa made Toyota 12V batteries typically last 6-10 years.
Parts store batteries last 2-3 years.
Optima yellow tops last 2-4 years, cost 25% more than Toyota, cost 50% more than parts store.
All are AGM. All are mounted inside the vehicle cargo area (not in the hot engine compartment). All vehicles had properly functioning charging systems.
This is essentially a standby application. The Prius 12V does nothing more than power the computers for a few seconds at 10-20A (0.25 - 0.5C). Once the hybrid battery is connected, 12V power/charging is provided by the DC-DC converter powered by the HV system. The 12V is charged to 14.2V and then floats at 13.6V almost immediately. The Prius 12V battery is erroneously referred to as the starter battery. It does not start the engine. The HV battery spins MG1 with 30A and about 220VDC to start the engine.
In the only incident of its kind, an Optima at just under two years in service vented aggressively into the passenger compartment. It blew off the vent tube and vented with enough force to produce a high pitched whistling sound. The entire car wreaked of that over-charged sulfur stench... at 14.2V. The battery was so hot, it was painful to the touch.
Opima warrantied the battery.
In my experience it is a premium priced product that underperforms less expensive options.
In Phoenix, AZ:
If it's any consolation, we swapped the gils out of two of our planes and replaced them with dual Optima blue tops (to get 24v) they are being tended with those battery minder tenders you linked to earlier.Yeah, they totally suck. The battery is expensive, but make sure you NEVER give it a full charge with your own charger first, to make sure that the cells are never properly balanced and fully charged at the outset. And that means taking it to 14.7v CV. At least once, but most consumers do the drop-in and cross fingers thing.
Instead, just do a parking-lot swapout and rely on a vehicle to never give the optima it's "first birthday" charge. Quite important. Especially if you were handed one off the shelf gathering dust for a year.
Do the same thing for any series connected 24 or 48v solar bank. Just slap em in. Never give them a good first charge on your own charger.
You guys continue on how they SUCK. If they don't work in your application, switch back. No skin off my back, and can't get riled over it any more.
It makes me mean, and feel like winning an argument, rather than discussing technicalities, and that's bad.
