Lol. Sorta sounds like they just put a full bridge rectifier and a capacitor on the generator's 240vac output and.. charged more money im guessing? I didn't check the link, but im assuming they charged more money.
I put a push mower engine on a riding mower (and put a small crane on it too) and i was able to find a random V belt pulley from my box of random pulleys (car guy thing, long story) and i found a pulley with a pressed in bearing that i was able to press out, and the ID of that pulley was close enough that i was able to just press that pulley onto the top side of the push mower's 'blade hub'.
But even more interesting.. I found that the indexing 'nubs' and 9/16" central centering 'hub' actually correlate perfectly to the water pump snout and pulleys of many, many old RWD american vehicles. Which means, you can pick a desired pulley diameter water pump pulley from some old tank in a junkyard, have it center perfectly on your push mower blade hub, drill and tap the middle of the indexing 'nubs' for some hold-down bolts, and have a large enough pulley to get full rpm on the alternator without having to overspin the push mower engine.
These and other tips brought to you by 'a mad tinkerer who has done a lot of goofy shit'. ?
