chrisski
Solar Boondocker
- Aug 14, 2020
- 5,310
Is discharging to 11.5 volts a technique you use frequently and your batteries have lasted for years? If so, then you are correct; otherwise I can only go off what is on spec sheets and user manuals. Too expensive for me to experiment. If it works for you, I’m still reluctant to experiment off one good result.So you prefer a 16 volt overcharge with the caps off and little drops of electrolyte jumping out and the place stinking like yellowstone vs drawing them down to 11.5v fairly quickly and then charging them back up at 14.4 with some decent amps?
How is the overvoltage way of stirring the electrolyte better?
I think the most important thing is to follow whatever spec sheet the battery has.
I prefer to not draw batteries below 50%. At 11.5 volts on a FLA battery, that is just above 10% SOC, 90% DOD. Going below 50% is supposed to significantly reduce the life of a battery. My chart puts 50% DOD at 2000 cycles, and stops at 20% DOD is 1000 cycles. 10% is not listed. Not somethign I want to do when spending over $1k for four GC2H golf cart sized solar batteries, or even cheaper GC2 golf cart batteries from COSTCO.
I’m assuming an FLA battery. The Trojan user manual I have says a battery should be equalized monthly. When I did equalize you could here it bubbling, which is certainly circulating the electrolytes.
I did not equalize monthly. I did add water monthly and check specific gravity, and this is a good way to circulate the electrolyte. Take it into and eject from the hydrometer three times before measuring. If the electrolyte is out of tolerance, than equalize. Mine was almost perfectly matched for the 18 months I had the batteries and only equalized once.
