Question for thought.
Charger plugged into the normal home wall outlet, that is directly connected to the System Bus Bar in the output end. 12v System. System built for backup of Gas Furnace in case of Power Outage.
Wall outlet - Charger - Bus bar - Battery - Bus Bar - Inverter (not plugged in or turned on until needed) - Furnace.
Does that make this whole system grounded?
