I've got 8 200ah lifepo4 cells. They are in parallel for top balancing.
I've got a power supply that is pushing amps. It says it is pushing 10 amps @ 3.44 volts (I set a limit of 3.65 volts). That's 34 watts approx.
It's been running for almost 3 days with very small increases in the voltage (It started at 3.37 volts).
Even if the cells were 50% depleted, that's 2400 wh. At 34 watts, that's 70 hours.
Am I to assume the batteries were more than 50% depleted?
How long will this take?
This is the power supply I have: https://smile.amazon.com/gp/product/B087TK6ZM2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
