Partimewages
Yep, some like to be the smartest in the room!
Wow, for this beginner this thread has blown what little grey matter I had left to scrambled egg.
So simple question. Should I be setting a tail current of 3.4A for my 340ah battery on the victron smart solar MPPT App Victron connect, or should I be leaving it disabled which is the default setting?
got a question for you... if you do not like what that person has to say on his posts... why do you go out of your way to look for them? is it a mentla sickness, do you need this arguing to feel special? do you need to feel like the white night charging in to save the day? or are you just a horrible person? you could put him on ignore if you dislike him that much instead of taking time to shitpost....... is that you, my @Solarcabin Channel friend?
Since most batteries are top balanced, you will likely hit 2.5V with one of your cells if you try discharging to 2.8VThis seems to be very interesting. It made me think of a few questions now. (which have probably been answered a million times before already)
Is 3.0V the minimum cutoff voltage for LFP?
What about 2.9V or 2.8V? What are the drawbacks of setting it to 2.8V or 2.9V?
Will it shorten the life of the battery?
Another is what if i just charge it to 3.45V instead of 3.5V? Will I lose alot of capacity or just a few?
In my situation,the charging amps is maximum 40A (usually 30A) for any given system. (either 12 or 24 or 48V)
A very safe cutoff voltage for LFP.Is 3.0V the minimum cutoff voltage for LFP?
It is important to understand why datasheets use the 2.5 V 'number'.What about 2.9V or 2.8V? What are the drawbacks of setting it to 2.8V or 2.9V?
For instance, here is the datasheet for my CALB cell.
It says, the cell was discharged at 1C constant current until the cell hits 2.5 V.
Because every cell has some internal resistance, when the 1C load is removed at 2.5 V, the cell voltage 'jumps back' to some higher voltage.
To find the same for a battery with multiple cells in series, discharge with rated constant current, until one of the Cell hits 2.5 V. Then note the voltage of that cell after recovery. That in theory, represents the absolute minimum cut-off voltage for LFP.
I don't have the money and equipment to test it with factory new cells, but I suppose it is somewhere around the ~2.8V mark.
If you take two LFP Cells,Another is what if i just charge it to 3.45V instead of 3.5V? Will I lose alot of capacity or just a few?
Just give me your thought process and proper reasoning behind what you think is the 'ideal discharge cut-off voltage' and how I'm supposed to physically determine it for my hardware.Please cite a reference, or disclose that you have just made this up. Where has the manufacturer published discharge voltage vs. C rates? This "standard discharge model" is used to validate the capacity specification.
Just give me your thought process and proper reasoning behind what you think is the 'ideal cut-off voltage' and how I'm supposed to physically determine it for my hardware.
It is that simple.
Exactly my point.As someone with an advanced technical degree, you understand this very basic requirement: You've made a claim. Now you must provide evidence to support it.
You don't get to make an unsubstantiated claim and then say, "prove me wrong" when challenged.
Requesting mods to bless us with a 'facepalm' emoji. This is actually too funny.We all know that's not going to happen!
?Requesting mods to bless us with a 'facepalm' emoji. This is actually too funny.
My bad. I meant a facepalm reaction.?
Claims to be a facepalm but sure doesn't show up very well.
Not getting in this discussion just pointing out we do have one
Something like this ?My bad. I meant a facepalm reaction.
Thanks for that....certain discussions/posters should just be ignored cause they are only here to cause trouble. Some call them trolls.?
I vote for #2!Something like this ?
or maybe this ?
