Active balance at 3.3? I thought balance needs to happen at a higher voltage. Perhaps I’m thinking of only passive balance. I don’t know much about active balance.Hmmmm
I Bulk/Absorb charge to 3.450Vpc and Float at 3.430Vpc. Active Balance on @ 3.300 trigger 0.010 deviation. By the time the packs reach float, the deviation is <0.020 and completely balanced & topped within an hour. Float then continues to service Inverter loads till the sun drops & the batteries start to supply the inverter.
I use the correct EndAmps/Tailcurrent with the system to determine when to switch to float, as per industry spec.
That is calculated as follows: 100AH * 0.05 = 5A or 280AH * 0.05 = 14A
I don't have experience with LFP, so maybe this is obvious, but if cells are best balanced if there's no load, how do cells get balanced on systems that always have a load? My LA system is never unloaded.
OK. I get it. Yeah, they get to float. I didn't make the connection to float and balance. Cells are balanced when there's enough PV to power the loads, am I on the right track?LFP cells are primarily balanced in the absorption stage with a little (sometimes a lot) in the float stage.
Are you saying your batteries are never in float?
Watch this video again, I think you missed some details.So I basically made up my mind next to figure out Inverter-BMS communication and possibly replacing the BMS if that wasn't possible. Long story short, I was watching DIYBMS videos and stumbled across one particular video about 'floating' lithium cells -and read the article by Nordkyn. (Excellent and mandatory read all the way BTW!!)
Active is moving power not burning it off. I tinkered with this through all of the testing phases & my nasty Thrash tests (pushing to the limit edges" and realized pretty quickly that starting Active balancing at a lower cell voltage actually takes the edge off. With the mix of cells I have, Used EV cells, Bulk, B & A grade, I got to see a bigger picture overall.Active balance at 3.3? I thought balance needs to happen at a higher voltage. Perhaps I’m thinking of only passive balance. I don’t know much about active balance.
A few things I have noticed with cell balancing as well, that many people push hard or talk about;
1) Changing the voltage of when the balancing turns on isn't very important. Think about it, even cells that are severely out of balance, still have relatively the same voltage under 3.4v. So if 1 cell is 90% at 3.38v, and 99% at 3.385v (totally random numbers, not actual values, but just an example), and the BMS is set to not balance under 10mV, then the BMS will not start balancing. So you can set balancing to turn on at 3.2v, or whatever, because the delta wont grow more than 10mV unless the deviation is extreme. So in @Steve_S example, setting to 3.3v I think is no problem. If the cells are under 10mV then there is no balancing, and this will be true even above 3.6v! If the cells are under 10mV, then no balancing will occur.
2) Balancing while charging, In my personal opinion, is not good. Like stated in earlier posts of this thread, the voltage is too volatile while charging, so the balancer might be fighting itself and making the problem worse. If you can program to only balance when current is under .01-.05C, then that would be ideal. This would also rely on the battery not being in use for a period of time, which like mentioned by someone in this thread, is sometimes not feasible.
3) This one is more personal preference. I am not an electrical engineer, nor do I have any proof about this statement, its just how I feel. Charging to a higher voltage (3.5-3.55v) is not as detrimental as some may perceive. I bulk/absorb to 3.5v/cell (56v), and then float at 3.4875v/cell (55.8v). This forces my Seplos BMS to register 100% SOC by hitting the 56v overall pack voltage, and then slightly lowers voltage, allowing for balancing to be easy to identify which cell is high/low. This circles back to what I say in a lot of posts, Calendar aging will kill the pack before cycle life! USE YOUR BATTERIES!
In my post, I've provided exactly that.Can you please let everyone know what your point is?
If it's the subject line, you haven't provided conclusive evidence to support it.
It's mostly a wall of text that is exhausting to read.
Except in my case, because I'm charge terminating correctly, my cells are showing below 0.01 V balance at rest even after three charge cycles with the balancer completely turned off.Why? Cycling doesn't balance cells.
It might as well be written in hieroglyphics.In my post, I've provided exactly that.
No, your cells are still balanced because you balanced them recently and now are only charging them to the very bottom of the voltage knee, where the cell voltage just starts to deviate. There's a wide flat spot on the voltage curve where cell voltage can't be used to infer SOC or capacity.Sorry for the wall of text.
I haven't reinvented anything, but this is still widely observed mostly because most people don't know this is what their cell's datasheet means.But you aren't reinventing the wheel or revealing some long lost secrets. Enter the termination current or just use voltage if your charger doesn't support termination current they're just leaving some capacity on the table to stop based on voltage only.
Really? I thought resting voltage at 50% was nearer to 3.3V? All my new grade A EVE cells arrived with 3.29V, which I understood was because they should be shipped / stored at about 50% SOC. Never seemed there was much energy left in them when they dropped to 3.2V either.LFP Nominal cells voltage = 3.200V which is 50% SOC per manufacturer specs for the chemistry.
What they are shipped at is never exactly 50%, could be anywhere between 30-70% in my experience.Really? I thought resting voltage at 50% was nearer to 3.3V? All my new grade A EVE cells arrived with 3.29V, which I understood was because they should be shipped / stored at about 50% SOC. Never seemed there was much energy left in them when they dropped to 3.2V either.
Good point, but I'm still not convinced 3.2V is 50%?What they are shipped at is never exactly 50%, could be anywhere between 30-70% in my experience.
