Tulex
Solar Wizard
Built 2 48v batteries with Seplos 200a bms. Both batteries will charge and discharge fine. Both batteries will be balanced within 5-10 mv when discharged to 20%, one battery will charge within 15mv or so before balancing, but the other is usually off by over 50 mv. The bms will balance it eventually. I know the reason, I had to have 3 cells replaced due to damage in shipping, and these 3 cells are always the 3 that hit high voltage first. I find it interesting that they drain balanced, but charge imbalanced.
Regardless, will these cells always charge faster than the rest, or will they eventually even out?
A side question. I have these batteries wired individually to separate breakers in the inverter (Sol-Ark 15k). Is this still considered in parallel? I have them as a master and slave, the master connected to the inverter via can. I know that if one battery stops charging due to an alarm and is waiting to recover, once it comes out of alarm, it will draw from the other battery until the battery volts balance. But, I've only heard the term in parallel used when they are actually connected together.
