I have three of the valance Wil P specials in parallel for my camping trailer. It serves the fridge and my cpap needs a few led strips and charging phone duties. I have an aili shunt for external monitoring, a Victron solar charge controller for field recharging and a renogy dc/dc for tow charging. At home I have a ctek life charger that I can plug in for driveway duty. Everything is off when I’m home as in the fridge is unplugged and the power ports are switched off. The only draws are the Victron battery protect which sits between battery bank and 12 station distrib panel and the Victron solar charger which some load circut is the fridge (unplugged).
Issue:
I’m trying to calibrate the aili shunt. The batteries die even with the cut off voltages set at 11.5volts.
Method:
Charge fully the pack with the ctek until it’s not taking any more charge per the aili shunt and the farthest green light on the charger is lit
Plug in fridge: onboard fridge disconnect is set at 10.7, Victron load cutoff set at 11.5v, battery protect not in fridge circut but it’s cut off is set at 12. Theoretically my cpap will stop before the fridge does making fridge the priority. The renogy dc/dc is off and no power fro
Tow vehicle it’s just sitting there.
I’m trying to discharge to disconnect or 11.5v with the shunt set to 500 amp hours to see how many amp hours I have to play with to set the shunts counter at for an accurate displayed percentage and graph.
This is the second attempt to do so with the first cut off set to 10.7 mimicking the fridge cut off. I came home after a few days and the valance bms had cut power itself and batteries showed 1.5v post to post. Mild panic, woke up batteries with 12 volt 2amp to 12volts post to post then on ctek charger to full. Then repeat discharge with above numbers. Again found pack dead as shit aili meter off everything dead. Currently waking up my pack again as we speak.
Wtf!?
Issue:
Method:
Wtf!?
